Ehren Posted July 12, 2018 Author Share Posted July 12, 2018 6 hours ago, encontinuo said: Hi! The Nightly updates can be applied with this method? Much thanks! Yes. Add the code to the child theme. Link to comment Share on other sites More sharing options...
encontinuo Posted July 12, 2018 Share Posted July 12, 2018 Ok perfect Ehren! Link to comment Share on other sites More sharing options...
encontinuo Posted March 28, 2019 Share Posted March 28, 2019 Hi again Ehren, Sorry I have a question. Now I want to update the Invision Community v4.3.5 to actual one 4.4.2 The theme version is; /* 4.3 theme by ipsfocus.com */ :root{ --ipsfocus-version: '4.3.4'; --ipsfocus-date: 'July 7, 2018'; } What I have to do, install as fresh version or simply install the new theme updating the patent theme? Many thanks! Link to comment Share on other sites More sharing options...
Ehren Posted March 28, 2019 Author Share Posted March 28, 2019 59 minutes ago, encontinuo said: Hi again Ehren, Sorry I have a question. Now I want to update the Invision Community v4.3.5 to actual one 4.4.2 The theme version is; /* 4.3 theme by ipsfocus.com */ :root{ --ipsfocus-version: '4.3.4'; --ipsfocus-date: 'July 7, 2018'; } What I have to do, install as fresh version or simply install the new theme updating the patent theme? Many thanks! There are reverted template files in the latest update which aren't applied if the "Upload new version" method is used. I'd suggest installing a fresh version if possible. If not, the instructions for reverting the template files can be found in the News topic. Link to comment Share on other sites More sharing options...
encontinuo Posted March 29, 2019 Share Posted March 29, 2019 Ah ok Ehren i will do a fresh install, I see it says something related to is prepared for auto updates so the question is; What is now better in this new scenario a normal install method or parent child? Thanks a lot! Link to comment Share on other sites More sharing options...
Ehren Posted March 29, 2019 Author Share Posted March 29, 2019 7 hours ago, encontinuo said: Ah ok Ehren i will do a fresh install, I see it says something related to is prepared for auto updates so the question is; What is now better in this new scenario a normal install method or parent child? Thanks a lot! Parent/child setups are always best. Link to comment Share on other sites More sharing options...
encontinuo Posted April 1, 2019 Share Posted April 1, 2019 Ok thanks Ehren, And after this update the next ones will be done automatically without doing nothing? Link to comment Share on other sites More sharing options...
Ehren Posted April 1, 2019 Author Share Posted April 1, 2019 3 hours ago, encontinuo said: Ok thanks Ehren, And after this update the next ones will be done automatically without doing nothing? It depends if IPS adjusts the template files But the latest update will be more upgrade-friendly than earlier versions since it has less modified template files. Link to comment Share on other sites More sharing options...
encontinuo Posted April 10, 2019 Share Posted April 10, 2019 Ok thanks Ehren! Link to comment Share on other sites More sharing options...
encontinuo Posted July 2, 2019 Share Posted July 2, 2019 Hi Ehren, Sorry I'm a little lost about the last update. It's an autoupdate? What I have to do to update from Subway 4.4.2.0 to the last one? Much thanks! Link to comment Share on other sites More sharing options...
Ehren Posted July 2, 2019 Author Share Posted July 2, 2019 8 minutes ago, encontinuo said: Hi Ehren, Sorry I'm a little lost about the last update. It's an autoupdate? What I have to do to update from Subway 4.4.2.0 to the last one? Much thanks! Instructions are available in the topic in the Client forum Link to comment Share on other sites More sharing options...
encontinuo Posted July 2, 2019 Share Posted July 2, 2019 Ok I will do a new fresh install, sorry I never understood exactly how to do, when is posible to autoupdate and when is needed to do a fresh update... Link to comment Share on other sites More sharing options...
Sir.Angry Posted July 20, 2019 Share Posted July 20, 2019 Where Is Admin Cpanel? Link to comment Share on other sites More sharing options...
Emanuelxd Posted August 4, 2019 Share Posted August 4, 2019 Me aparece el sitio sin estilo, espero me ayudes Link to comment Share on other sites More sharing options...
Ehren Posted August 5, 2019 Author Share Posted August 5, 2019 7 hours ago, Emanuelxd said: Me aparece el sitio sin estilo, espero me ayudes That doesn’t seem like it’s IPS forum software.. Link to comment Share on other sites More sharing options...
dokdok Posted February 17, 2020 Share Posted February 17, 2020 Hi, 2 questions On 3/29/2019 at 9:44 PM, Ehren said: Parent/child setups are always best. 1) Is this solution still valid? I remember a while ago not advising you for problems encountered with IPS changes ... 2) For the transition from Chameleon Dark 4.4.9.2 to 4.4.10, is it possible to simply update the theme or do you recommend a new installation? Link to comment Share on other sites More sharing options...
Ehren Posted February 17, 2020 Author Share Posted February 17, 2020 I use a parent/child setup on my demo board, however I manually upgrade my themes so I'm not sure what method is actually best if you're using the "Upload new version" feature.. I'd suggest trying to use the Upload New Version feature to see if it works correctly. When given the option, just make sure you use the "new" code instead of the old code. 1 Link to comment Share on other sites More sharing options...
Nithin Posted February 19, 2020 Share Posted February 19, 2020 Hi I am not able to understand it I have downloaded the theme in the form of .zip and even I have extracted it and I have got the .xml file also where can I get or search the admin cpannel it is available or looking to me on my tab please reply to this topic Link to comment Share on other sites More sharing options...
Ehren Posted February 19, 2020 Author Share Posted February 19, 2020 4 hours ago, Nithin said: Hi I am not able to understand it I have downloaded the theme in the form of .zip and even I have extracted it and I have got the .xml file also where can I get or search the admin cpannel it is available or looking to me on my tab please reply to this topic Hello, Are you using Invision Community? Link to comment Share on other sites More sharing options...
Nithin Posted February 20, 2020 Share Posted February 20, 2020 Yes I have signed in but nit getting anything it is showing only the free themes in that site so what can i do Link to comment Share on other sites More sharing options...
Nithin Posted February 20, 2020 Share Posted February 20, 2020 Can i create a forum site like the above image as shown. If yes please help me out to create like that site Please Link to comment Share on other sites More sharing options...
Deano Posted February 20, 2020 Share Posted February 20, 2020 Hi @Nithin, click on (where arrow is pointing in your image below) > Account > AdminCP. once you have logged into your admin panel, click on the paint brush (last icon on the left hand side), under appearance select themes > over to the right you will see a orange button that says +Add Theme > select upload theme > then find the theme XML file on you PC. from there, the rest should be self explanatory. Link to comment Share on other sites More sharing options...
Nithin Posted February 21, 2020 Share Posted February 21, 2020 No,that is not my site.I need to create a site like that on this forum site So i asked how to do in the forum site Link to comment Share on other sites More sharing options...
Deano Posted February 21, 2020 Share Posted February 21, 2020 3 hours ago, Nithin said: No,that is not my site.I need to create a site like that on this forum site So i asked how to do in the forum site Ok, I see. if that is the case, if you aren't familiar with how it is done, I would recommend you getting familiar with the demo from the official IPB site. they have many options that you can choose from such as self hosting etc. 2 Link to comment Share on other sites More sharing options...
chirticvlad@gmail.com Posted March 8, 2020 Share Posted March 8, 2020 Hello, I have purchased the ChameleonDark theme and I'm trying to install it on my wordpress page. When I upload it I get an error saying that The package could not be installed. The theme is missing the style.css stylesheet. Link to comment Share on other sites More sharing options...
