Ehren Posted April 7, 2015 Posted April 7, 2015 By default, IPS.Suite 4.x uses your website name as it's logo. To use an image instead, go to Admin Cpanel > Customization > Themes > Edit > Logos Next to Site Logo Image, upload your logo and press the Save button. If you wish to revert back to a basic text logo, go back to the Logos page, toggle the Remove custom site logo switch, and press Save. 5
Daifuku Posted August 2, 2016 Posted August 2, 2016 Hello, how do I remove the logo completely? I don't want to have a logo displayed there if possible. Greetings!
Ehren Posted August 3, 2016 Author Posted August 3, 2016 4 hours ago, Daifuku said: Hello, how do I remove the logo completely? I don't want to have a logo displayed there if possible. Greetings! For your current theme (Chameleon), add the following to custom.css #elSiteTitle{ display: none; }
Haunted Posted September 12, 2016 Posted September 12, 2016 Hello, I have a custom logo image, but would like to redirect it back to the home page of my site. Is there a way to do this in the admin panel somewhere?
Ehren Posted September 12, 2016 Author Posted September 12, 2016 7 hours ago, Haunted said: Hello, I have a custom logo image, but would like to redirect it back to the home page of my site. Is there a way to do this in the admin panel somewhere? You'd need to edit the URL of the link inside the logo template file. I think that's the only way.
Haunted Posted September 13, 2016 Posted September 13, 2016 Thanks for the reply! Can you please tell me where (what directory of the FTP) that would be located? Currently the logo just redirects to the forums. I didn't install the forum, but it's a custom logo in the header, and I am having trouble locating the file.
Ehren Posted September 13, 2016 Author Posted September 13, 2016 It's done in your ACP, not via FTP ACP > Customization > Themes > Edit HTML and CSS > logo
Haunted Posted September 14, 2016 Posted September 14, 2016 Thanks, Ehren. I appreciate the help. I am not very savvy with these types of things. Can you please tell me which part of the editor I would find this? This is what I see in the "Logo" section: {{if \IPS\Theme::i()->logo['front']['url'] !== null }} {{$logo = \IPS\File::get( 'core_Theme', \IPS\Theme::i()->logo['front']['url'] )->url;}} <a href='{setting="base_url"}' id='elLogo' accesskey='1'><img src="{$logo}" alt='{setting="board_name" escape="true"}'></a> {{else}} <a href='{setting="base_url"}' id='elSiteTitle' accesskey='1'>{setting="board_name"}</a> {{endif}} Currently, the navigation is that clicking on the logo when the user is already at "www.websitename.com/forum" will just direct to "www.websitename.com/forum" which the "home" button already does in navigation menu. I would just like the logo to navigate back to "www.websitename.com" and am having trouble locating where to change this. Thanks in advance for any insight!
Ehren Posted September 14, 2016 Author Posted September 14, 2016 Change both instances of {setting="base_url"} to your new URL. There may be a setting which achieves the same effect but it may unintentionally modify other links on your site too.
Haunted Posted September 14, 2016 Posted September 14, 2016 Hmm. That seemed to add the url to the end. So it now shows as "www.website.com/forum/website.com"
Ehren Posted September 14, 2016 Author Posted September 14, 2016 Make sure you entered the entire URL, including http:// at the start.
Ehren Posted January 8, 2017 Author Posted January 8, 2017 2 hours ago, Riley said: Hi, how do I get rid of my text logo? There's already a tutorial for that Just remove the text from the "Text Logo" setting and it'll use your site name. Otherwise upload a logo under the "Logo" tab by reading this topic.
Riley Posted January 8, 2017 Posted January 8, 2017 13 minutes ago, Ehren said: There's already a tutorial for that Just remove the text from the "Text Logo" setting and it'll use your site name. Otherwise upload a logo under the "Logo" tab by reading this topic. I did but the default site name is there.
Ehren Posted January 8, 2017 Author Posted January 8, 2017 The image should be displayed if you've uploaded it via the Logo tab. Use the System > Support feature in your ACP to clear your cache and see if that helps.
Riley Posted January 8, 2017 Posted January 8, 2017 11 hours ago, Ehren said: The image should be displayed if you've uploaded it via the Logo tab. Use the System > Support feature in your ACP to clear your cache and see if that helps. Sorry maybe I worded it wrong, what I want is no-logo and no-text or site name in my header at all.
Ehren Posted January 8, 2017 Author Posted January 8, 2017 Add the following to custom.css .ipsApp a.logo{ display: none; }
Behzad4x Posted October 24, 2017 Posted October 24, 2017 Hello, Dear Ehren, how set logo in center of page in Mobile view? Regards.
Ehren Posted October 24, 2017 Author Posted October 24, 2017 6 hours ago, Behzad4x said: Hello, Dear Ehren, how set logo in center of page in Mobile view? Regards. Hello, What theme are you using? 1
Behzad4x Posted October 24, 2017 Posted October 24, 2017 2 hours ago, Ehren said: Hello, What theme are you using? I'm using Default IPS theme. My logo isn't center in the Mobile view. It's in right side. (My site's language is Persian and it's RTL ) Best Regards.
Ehren Posted October 25, 2017 Author Posted October 25, 2017 3 hours ago, Behzad4x said: I'm using Default IPS theme. My logo isn't center in the Mobile view. It's in right side. (My site's language is Persian and it's RTL ) Best Regards. I can't see your logo at all, even on desktop
Behzad4x Posted October 25, 2017 Posted October 25, 2017 9 hours ago, Ehren said: I can't see your logo at all, even on desktop This is my site's address: http://brokernews.ir Logo is visible for me. Thanks.
Behzad4x Posted October 30, 2017 Posted October 30, 2017 On 25/10/2017 at 6:34 AM, Ehren said: I can't see your logo at all, even on desktop Hello again, Dear Ehren, now you must could see my logo in site, the problem is solved: http://brokernews.ir But my logo is not in center in mobile view. Also my logo has low quality beside desktop. Quality in desktop is ok but in mobile it is blur. Please help me to correct this problems. The support ips can't not solve this problems. Regards.
Ehren Posted October 30, 2017 Author Posted October 30, 2017 39 minutes ago, Behzad4x said: But my logo is not in center in mobile view. Also my logo has low quality beside desktop. Quality in desktop is ok but in mobile it is blur. Add this to custom.css @media (max-width: 767px){ #elLogo{ display: block; text-align: center; } } I'm unsure about the low quality, sorry.
