JulienBayle Posted August 5, 2011 at 04:52 PM Posted August 5, 2011 at 04:52 PM Hello, I'm desperately looking for pro themes/skins for IPB. I'm especially looking for A REALLY PRO & NICE integration with IP.Content in order to: - have a REAL homepage with eventually banners & dynamic content - have a couple of static pages (with IP.Content) - use ALL IP.Nexus + IP.Blog + IP.Download + ++ modules The skin used on this website would fit well (btw, I didn't check yet the IP.Download & IP.Nexus sections... Any ideas? Links ? Name of Skin ? I found almost only those bad skins with different design on each parts :-( Any infos would be appreciate! Best, Julien
The Heff Posted August 5, 2011 at 09:29 PM Posted August 5, 2011 at 09:29 PM http://www.rsobb.co.uk/ <-- Infinite and Infinite Dark with IP.Content (change themes at the bottom).
JulienBayle Posted August 5, 2011 at 09:44 PM Author Posted August 5, 2011 at 09:44 PM hello, thx for the link. it looks as a "portal" too much. I'm more in a way like the actual website (http://designthemedia.com) than this one. I'd like to know what is used here (I mean here: http://www.ipbforumskins.com)
The Heff Posted August 5, 2011 at 10:22 PM Posted August 5, 2011 at 10:22 PM Then you probably want this link: http://www.ipbforumskins.com/custom_request.php
Ehren Posted August 6, 2011 at 01:51 AM Posted August 6, 2011 at 01:51 AM hello, thx for the link. it looks as a "portal" too much. I'm more in a way like the actual website (http://designthemedia.com) than this one. I'd like to know what is used here (I mean here: http://www.ipbforumskins.com) The main pages of this site are custom coded with php/html. They're not actually integrated with the forum.. they have just been coded using the same html/css.
JulienBayle Posted August 6, 2011 at 06:35 AM Author Posted August 6, 2011 at 06:35 AM Then you probably want this link: http://www.ipbforumskins.com/custom_request.php DiD! The main pages of this site are custom coded with php/html. They're not actually integrated with the forum.. they have just been coded using the same html/css. Got it. I guess we could do that with IP.Content too. right? I made a custom request. If the price is ok for my budget, I'll go with it.
