A few questions about Dispersion
  1. If I buy it for 3.x.x tomorrow will I have access to the 4.0 version in the next few months? (I will be paying the renewal fee every six months by direct debit)
  2. Is there any way to turn off the animated gradient? I know it's one of the skin features (and I love it) but my partner wants to know if our default version could have it switched off?
  3. What kind of support do you offer for these skins? I don't plan on coming to you with every problem, but I'd like to know what the extent of the help might be.
Thank you in advance. :D
Hi Claire,
1. Yep, the 4.0 version will be available hopefully within a couple of weeks, if not earlier :)
2. Yep. There will be a way to disable the animation, a way to disable the random gradient position, and even an option to remove the gradient entirely if desired.
3. The testimonials should give you a good idea on the support quality :) I'm on this site every day and if any customer is having an issue with their site, I try and find a solution as soon as possible. :)
Hope that helps!
Very much so! Thank you!
And wow... those testimonials are fantastic! I shall hopefully be purchasing Dispersion today! :D
As I've already indicated, I will probably we looking to you for a custom skin and an upgrade for an IPB3 skin (to IPS4) in the future. I always come back here when looking for quotes, lol
