Dave qp Posted July 30, 2015 Posted July 30, 2015 Hi Ehren When the (awesome) snapshot theme is updated for 4 will you still be able to close down the side bar (latest files, recent topics etc.) ? Thanks Dave
Solution Ehren Posted July 30, 2015 Solution Posted July 30, 2015 Hi Dave, That feature was removed in 4.x, so it will no longer be available in Snapshot.
Dave qp Posted July 30, 2015 Author Posted July 30, 2015 Thanks for the quick reply Ehren I don't currently have a forum, can those be switched off in the admin?
Ehren Posted July 30, 2015 Posted July 30, 2015 The side blocks can be configured by visiting your forum, signing into an admin account and clicking the "arrow icon" on the left side of your screen.
Empire Posted July 30, 2015 Posted July 30, 2015 Isn't there a easy way to add costume HTML block that suits with the other blocks. I made up a test block but where the block name with The blue background doesn't show. I have posted this on IPS site
Empire Posted July 30, 2015 Posted July 30, 2015 Here is that topic https://community.invisionpower.com/topic/418681-questions-support/
Empire Posted July 31, 2015 Posted July 31, 2015 Looks like you got this sorted already.. Yep.. Is there another Way? And with the Pages app, I have set up an home page and I another "Test" Page. I wanted to have the Home page first then forum and then the Test page at last, after Download. all I can do is when I more the pages app it moves all pages to back.
Ehren Posted July 31, 2015 Posted July 31, 2015 All of the "Pages" navigation links need to be next to each other in the navigation bar as far as I know.
Empire Posted July 31, 2015 Posted July 31, 2015 All of the "Pages" navigation links need to be next to each other in the navigation bar as far as I know. well that's just silly. Should be a settings that also aloud to move the navigation bar not just the application.it's more easier in smf navigation then IPS. On lcpdfr.com they definitely did it and can't work it out
Ehren Posted July 31, 2015 Posted July 31, 2015 I could be wrong, so double check for yourself. Nothing I can do about it unfortunately, it's something you'll need to contact IPS about since your feedback is for their product
Empire Posted August 1, 2015 Posted August 1, 2015 I could be wrong, so double check for yourself. Nothing I can do about it unfortunately, it's something you'll need to contact IPS about since your feedback is for their product Additional Links in Navigation Bar 1.0.1 It's Solved 1
