Villain is a dark, semi-transparent dark skin which includes a simple background picker allowing your members to choose their own image from a preset array of high quality background images. Perfect for any community, and especially great for gaming forums or site who want to offer customization options to their members!
  • Like 5
It's been a couple years since I had the 3.x.x version, just bought the 4.x.x version.
Do I need to re-purchase the copyright removal or can I use the one I originally purchased?
Thanks!
The demo version is not working.
When i select it it does not work just reverts to Uniform, then is i manually change it from the change theme link i get the following error
Sorry, there is a problem
Something went wrong. Please try again.
Error code: 2S119/1
Error code: 2S119/1
I've updated the demo link, does it work correctly for you now?
http://ipsfocus.net/4x/index.php?/topic/38-how-does-a-penguin-build-its-house/#comment-66
maybe u should consider changing the design element and the color of answer and queston since it looks really obnoxious and bad
Thanks, I hadn't noticed that.. Will get it fixed shortly. :)
This class ".ipsItemStatus:not(.ipsItemStatus_large)", which is for the little circle placed to the left of unread topics titles, has some greyish blue color that doesn't feel good.
Guest Neo3
actually no, the ckeditor is white background so its really destroying my eyes when i use a dark theme like villain
How do you change the look of the toolbar? I get these error messages. Background images seem to be blurry, is there a fix for this?
There are a couple problems I'm seeing with the updated theme.
- Admin panel is near unreadable with this theme. Light colored text on light backround.
- Database feeds (articles). When you switch the database to display the actual articles instead of categories there is no spacing between new sentences. Looks like one big weird paragraph instead.
Back to 3.4.7 until these are resolved. ;/
Looks great Ehren!
Cannot wait to see Animate :)
I have one question though, do the dark skins include a matching CKEditor skin?
Animate will be nice too, it's done - just waiting for some bugs to be fixed. A dark ckeditor theme has been added to the client area (in the same place where you download the Villain files).
A dark ckeditor theme has been added to the client area. Instructions on how to install/assign are in the 4.x tutorials forum in the customer category.
Thanks, fixed. :)
IPS 4.x has a "feature" which tries to inherit the front-end theme and display it in the ACP. None of my themes will be supporting this feature since I believe the ACP should always stay unmodified. To change back to default, go to ACP > "Signed in as..." > AdminCP Theme > Default.
Does the same issue with database articles happen when using the default theme? If not, send me a URL to your forum if possible and I'll find a fix. :)
The Villain files in the client area have been updated with the above fixes.
Does this mean that Animate will be out soon? :D
Unsure if it is/was the same bug affecting both?
Animate is being affected by a different bug, it will hopefully be available for 4.0.8 :)
  • Like 2
