Ehren Posted March 8, 2020 Author Posted March 8, 2020 Hello, These themes are only compatible with Invision Community, they will not work with any other software such as Wordpress. The requirements are listed numerous times throughout the site, including on each theme page, the FAQ's and on the checkout page (screenshot attached).
robbie7605 Posted August 3, 2020 Posted August 3, 2020 On 4/6/2015 at 8:42 PM, Ehren said: 1. To install the Parent theme, go to Admin Cpanel > Customization > Themes. At the top right, click the + Add Theme button. Im new to this where do i go please help On 4/6/2015 at 8:42 PM, Ehren said:
talerchen Posted January 17, 2021 Posted January 17, 2021 Hello, Whe can install the Them in newest Version v4.5.4.2? All me Themes is in default light blue can i found here a tutorial?
Ehren Posted January 18, 2021 Author Posted January 18, 2021 4 hours ago, talerchen said: Hello, Whe can install the Them in newest Version v4.5.4.2? All me Themes is in default light blue can i found here a tutorial? Hello, Are you following the instructions in this tutorial? They are up-to-date and work with 4.5.x
Ehren Posted February 1, 2021 Author Posted February 1, 2021 10 hours ago, AlphaRP said: Where is the admin thing Hello, You can access your ACP by adding /admin to the end of your forum URL.
RyanMalik Posted March 9, 2021 Posted March 9, 2021 There is no AdminCpanel at the top left. All I see is Iceline Hosting and then the button below takes me to user management.
Ehren Posted March 9, 2021 Author Posted March 9, 2021 1 hour ago, RyanMalik said: There is no AdminCpanel at the top left. All I see is Iceline Hosting and then the button below takes me to user management. Hi Ryan, The theme needs to be installed using the Invision Admin Cpanel. Please check the FAQ's for more information
PavlivGroup Posted June 15, 2021 Posted June 15, 2021 After upgrading to version 4.6.0, it gives the following error: Quote [[Template core/front/global/userBar is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]] How to fix?
Dean_ Posted June 15, 2021 Posted June 15, 2021 Upload the updated one as a new theme and then copy over the settings from the old one. Ehren and most theme makers would recommend installing the theme as new on software upgrades like 4.5x, 4.6.x and so on. 1
Ehren Posted June 15, 2021 Author Posted June 15, 2021 4 hours ago, PavlivGroup said: After upgrading to version 4.6.0, it gives the following error: How to fix? Have you upgraded your software to 4.6.0 as well? The 4.6 themes will not work on Invision Community 4.5
Feneroin Posted June 15, 2021 Posted June 15, 2021 Hello @Ehren I have uploaded 4.6 theme creating child theme but on main theme, it's still show "Update available" it's normal?
Ehren Posted June 16, 2021 Author Posted June 16, 2021 2 hours ago, Feneroin said: Hello @Ehren I have uploaded 4.6 theme creating child theme but on main theme, it's still show "Update available" it's normal? Hello, Did you update the parent theme? When you update the parent theme, the child theme will automatically update too. Updating the child theme (instead of the parent theme) is the incorrect method. 1
Jan38 Posted September 2, 2021 Posted September 2, 2021 Hi Ehren, when i update IPS first to V 4.6 and after that the theme (Uniform) does the theme update retain the settings from the 4.5 version of the theme?
Ehren Posted September 2, 2021 Author Posted September 2, 2021 9 hours ago, Jan38 said: Hi Ehren, when i update IPS first to V 4.6 and after that the theme (Uniform) does the theme update retain the settings from the 4.5 version of the theme? Yeah, theme settings will be retained from your 4.5 version.
Jan38 Posted September 4, 2021 Posted September 4, 2021 Hi Ehren, In the theme settings i see buttons with almost every css setting that shows 'revert' if i revert all does the theme operate in standard mode (as you deliver the theme) or what does this?
Ehren Posted September 4, 2021 Author Posted September 4, 2021 2 hours ago, Jan38 said: Hi Ehren, In the theme settings i see buttons with almost every css setting that shows 'revert' if i revert all does the theme operate in standard mode (as you deliver the theme) or what does this? Clicking revert will reset those values back to the default Invision values, so it’s not usually recommended..
Jan38 Posted September 4, 2021 Posted September 4, 2021 2 hours ago, Ehren said: Clicking revert will reset those values back to the default Invision values, so it’s not usually recommended.. That's clear to me I have an issue, the amount of pages displayed on top of a discussion is hardly to be seen on my community, i thought that this reverting might be a solution. If i want to have the theme installed fresh (a reset) so the theme will display like it is created by you should i unstall and then re install or is there another method?
Ehren Posted September 5, 2021 Author Posted September 5, 2021 Yeah, a fresh install would be needed in that case. I have many ideas on how to improve the theme system for the next major Invision update, but I don’t imagine they’ll be implemented until a rewrite (potentially v5).
fhazal Posted April 6, 2022 Posted April 6, 2022 i already update the core theme, should i upload the new theme to my child theme that i create when installing the theme or no need?
Ehren Posted April 6, 2022 Author Posted April 6, 2022 7 hours ago, fhazal said: i already update the core theme, should i upload the new theme to my child theme that i create when installing the theme or no need? You only need to upgrade the parent theme. The child theme will inherit the changes 1
Guest Stormwolfe Posted August 17, 2022 Posted August 17, 2022 Is it still best to create child themes. I am using Dimension Pro so have a light and a dark theme for my users. Thanks!
Ehren Posted August 17, 2022 Author Posted August 17, 2022 2 minutes ago, Stormwolfe said: Is it still best to create child themes. I am using Dimension Pro so have a light and a dark theme for my users. Thanks! I’d still recommend it, yeah.
nodle Posted May 11, 2023 Posted May 11, 2023 So, I don't know what I am missing here. On the parent theme I clicked upload new version, and I thought the child theme was supposed inherit the changes, but it's still showing an update is available. What am I doing wrong? It's odd though since on the site it's showing that it did update: :root { --ipsfocus-version: "4.7.10"; --ipsfocus-date: "May 10, 2023"; }
