Dashboard Background
Dear Ehren
I love your dashboard theme and before purchasing I have a few questions I hope you can help me out with:
1. Can I upload my own background picture instead of the four options available on the demo?
2. Can font changes be made easily or does this require coding?
3. Finally, any examples of forums using the dashboard skin will be really appreciated. I can't seen to find any on google search.
Thanks in advance!
Mustafa
Hi Mustafa,
Welcome to ipsfocus
1. Yep - you'll also need a blurred version of the image though (for the left column). The blurred image can be omitted if necessary, but it looks nice if possible. :)
2. Yep, the font can be edited at the top of ipb_styles.css (it's a simple code edit).
3. Links to customer forums aren't provided, but you're welcome to check the demo board for a live version. :)
Hope that helps!
