abidbd Posted January 18, 2015 Posted January 18, 2015 Hi, I am new here and also new to invisionpower. To be honest, I am still researching if I should buy ips or vbulletin. I have some queries before I buy your theme. 1. I liked your Concise forum skin http://www.ipsfocus.com/premade/concise/index.php. But I found it is not responsive. Is there any chance or hope that you guys will make it responsive and when? Also, for now, if it is not responsive; then is there any mobile version of this skin? 2. To check if the theme is suitable in mobile and tablets or not, I checked the concise skin demo from my mobile, it didn't show any concise theme but instead is shows plain (or regular/normal) forum skin/look. Please clarify this. And if I buy concise theme, will it be the same in mobile for me too? Or have you used any addon or such for this mobile look? Or is it a default feature from invisionpower itself? 3. After purchase, do you provide any support and instruction on how to install the theme and how to do minor changes like color change or logo change etc.? 4. Is this theme can be used and is compatible with ips cloud? I haven't yet bought ips license, but as I am new, I am planning to buy ips cloud to test it for a month or two. Again, I will be using concise theme in ips cloud, is there any issue or restriction? Please clarify. 5. This skin is compatible with latest version of both ips cloud and self-hosted version, right? Warmly regards, Abid H.
Solution Ehren Posted January 23, 2015 Solution Posted January 23, 2015 Hello, Welcome to ipsfocus! 1. Themes made for IP.Board 3.4.x are not responsive. This will change in 4.x where all themes will become responsive. 2. For an optimized mobile experience, I'd suggest using the mobile IPB skin (which comes with IP.Board). Concise will not down-scale correctly on mobiles since it was only made for desktops. 3. Yep - any support questions can be asked in the customer forum. 4 & 5. The theme is compatible with the cloud version AND self-hosted version. Hopefully that answers your questions!
