Guest Newbee100 Posted August 28, 2014 at 06:53 PM Posted August 28, 2014 at 06:53 PM Hello, I Like Ortem Skin. Can I put a header and background on my taste after purchasing the theme. This will prevent you of the eventual update to version 4? Thanks in advance.
Ehren Posted August 29, 2014 at 01:08 AM Posted August 29, 2014 at 01:08 AM Hello, Yep - adding your own image to the header is very easy to do. You will also be able to add your image to your header in version 4.
Guest Newbee100 Posted August 29, 2014 at 05:35 AM Posted August 29, 2014 at 05:35 AM Thank you Ehren. I will be your customer soon.
Guest Newbee100 Posted September 1, 2014 at 09:02 AM Posted September 1, 2014 at 09:02 AM Hello, Yep - adding your own image to the header is very easy to do. You will also be able to add your image to your header in version 4. Can you image in the header is very large as header?
Ehren Posted September 1, 2014 at 09:35 AM Posted September 1, 2014 at 09:35 AM The header can be whatever size you like. You can simply use a background image and it'll scale to occupy the entire area. Instructions can be provided in the customer forums.
Guest Newbee100 Posted September 1, 2014 at 03:13 PM Posted September 1, 2014 at 03:13 PM The header can be whatever size you like. You can simply use a background image and it'll scale to occupy the entire area. Instructions can be provided in the customer forums. Again, quick customer support. Thank you!
Guest Newbee100 Posted September 1, 2014 at 03:30 PM Posted September 1, 2014 at 03:30 PM Now I saw the topic Snapshot. Is there a limit to the number of background that can be attached and used by consumers? Can include 20?
Ehren Posted September 1, 2014 at 11:40 PM Posted September 1, 2014 at 11:40 PM Now I saw the topic Snapshot. Is there a limit to the number of background that can be attached and used by consumers? Can include 20? You can add as many background options as you like. You'll also need to provide a blurred version of the image which requires a graphics editor. A .psd version of the background image is provided in the client area. 1
Newbee100 Posted December 10, 2014 at 01:58 PM Posted December 10, 2014 at 01:58 PM Hello, never managed to read whether the topic is responsiv Ortem. And I want to see how it looks on a smartphone and tablet?
Ehren Posted December 10, 2014 at 02:22 PM Posted December 10, 2014 at 02:22 PM The 3.4.x themes are not responsive, however the 4.x versions will be.
Newbee100 Posted December 10, 2014 at 07:32 PM Posted December 10, 2014 at 07:32 PM The 3.4.x themes are not responsive, however the 4.x versions will be. Too bad, obviously we have to wait a little longer.
Newbee100 Posted December 11, 2014 at 03:48 AM Posted December 11, 2014 at 03:48 AM Is there a topic that is responsiv version 3.4. Version 4 of IPB may be delayed and even then there will be no unpleasant responsiv.
Ehren Posted December 11, 2014 at 06:58 AM Posted December 11, 2014 at 06:58 AM Is there a topic that is responsiv version 3.4. Version 4 of IPB may be delayed and even then there will be no unpleasant responsiv. Not entirely sure what you mean. There is a hook which attempts to make themes responsive, but I'm not sure how well it works with 3rd party themes.
Newbee100 Posted December 11, 2014 at 07:46 PM Posted December 11, 2014 at 07:46 PM Now I will explain exactly what the problem is for that wonder.I'm torn and want to buy Ortem or Snapshot - Snapshot more. I realized that after passing the IPB 4 will receive a version of the theme for the new platform. Would it be then, responsiv topic? And how will it look like?A look of my forum with the current theme of a mobile device?These questions try to find an answer.
Ehren Posted December 11, 2014 at 10:50 PM Posted December 11, 2014 at 10:50 PM All themes will be responsive.. I don't have an example of what they will look like, but the "mobile version" will obviously be similar in design to the "desktop version", just slightly simplified.
Newbee100 Posted December 12, 2014 at 04:51 AM Posted December 12, 2014 at 04:51 AM So you have to decide which theme to buy, install it and wait IPB 4 to see the upgrade topic. If you need any changes to the settings on the passage of IPB 4 Can I count on your help? I mean the setting of the new version of the theme.
Ehren Posted December 12, 2014 at 02:32 PM Posted December 12, 2014 at 02:32 PM So you have to decide which theme to buy, install it and wait IPB 4 to see the upgrade topic. If you need any changes to the settings on the passage of IPB 4 Can I count on your help? I mean the setting of the new version of the theme. I don't quite understand what you're asking.. If English isn't your first language, use a translator such as Google to help
Newbee100 Posted December 12, 2014 at 07:11 PM Posted December 12, 2014 at 07:11 PM I don't quite understand what you're asking.. If English isn't your first language, use a translator such as Google to help :) Now will buy Ortem or Snapshot. Then, the subject will have a new version of IPB 4, right?Will this then any new settings in the Theme? Will I be able to count on help from you?
Ehren Posted December 12, 2014 at 11:43 PM Posted December 12, 2014 at 11:43 PM I still don't quite understand, however if you run into any problems, you can ask in the Customer forum.
Newbee100 Posted December 13, 2014 at 07:37 AM Posted December 13, 2014 at 07:37 AM Thank you, I have two last questions before you make a payment:Can I put a big logo in the header image of Snapshot - for example, to increase the height of the header? Because in the demo header is narrow and need to put a very small image of the logo.Can I change the color of the header settings?
Ehren Posted December 14, 2014 at 08:47 AM Posted December 14, 2014 at 08:47 AM Thank you, I have two last questions before you make a payment: Can I put a big logo in the header image of Snapshot - for example, to increase the height of the header? Because in the demo header is narrow and need to put a very small image of the logo. Can I change the color of the header settings? Yes, and yes.
Newbee100 Posted December 15, 2014 at 07:45 PM Posted December 15, 2014 at 07:45 PM Yes, and yes. Thank you, I will bye Snapshot skin. I will have support for header and logo. 1
