RtDClan Posted June 16, 2014 at 03:18 PM Posted June 16, 2014 at 03:18 PM Hi, Was wondering if Villain has the option to change it's width and/or make it fluid? Thank you.
Solution Ehren Posted June 17, 2014 at 12:17 AM Solution Posted June 17, 2014 at 12:17 AM Hi, Was wondering if Villain has the option to change it's width and/or make it fluid? Thank you. Hello, Yep - the width of Villian can be edited very easily by modifying one line of code. It can also be made fluid if necessary. Hope that helps!
Wo2dy Posted June 17, 2014 at 10:01 PM Posted June 17, 2014 at 10:01 PM Hello, Yep - the width of Villian can be edited very easily by modifying one line of code. It can also be made fluid if necessary. Hope that helps! He wanted to know if there is a feature to change the width instantly. Why my post was removed?
Ehren Posted June 17, 2014 at 11:48 PM Posted June 17, 2014 at 11:48 PM He wanted to know if there is a feature to change the width instantly. Why my post was removed? Your original answer was a little misleading. I believe RtDClan simply needs to know if the width can be edited - he wasn't asking if it was part of the configuration file.
Wo2dy Posted June 18, 2014 at 10:24 PM Posted June 18, 2014 at 10:24 PM Your original answer was a little misleading. I believe RtDClan simply needs to know if the width can be edited - he wasn't asking if it was part of the configuration file. All right. His post is confusing: Was wondering if Villain has the option This is not really an option, but a manual change.
