Subway Theme Question
Support regarding the premade themes is only offered to members in the Customers group. You'll need to purchase the skin first before using it on your site or asking for support.
Thank you :)
The height of the header area, and the size of the custom forum icons can be easily adjusted to accommodate for any size :)
The width of the logo should be short enough that it leaves room for the navigation links on the right side of the header.
