Jakub03 Posted December 17, 2013 at 04:28 AM Posted December 17, 2013 at 04:28 AM I have purchased a theme from you before and I loved it. I really like the design of the new theme dashboard that you have. I am curious on how editable the Navigation menu is. Would I be able to add more drop navigation panels with just links? Like add another section like the Navigation section but call it like Rakeback offers & under it have 10 different names and for the theme to be the same throughout.
Solution Ehren Posted December 17, 2013 at 04:33 AM Solution Posted December 17, 2013 at 04:33 AM Hello, The navigation is very easy to edit (however you will need some Photoshop knowledge for the icons). You can of course just have a menu without icons too (or just recycle the existing ones). You just need to wrap the links in one div, and they'll be styled automatically. Adding the collapse feature will require edits to the javascript files though. Basic instructions can be provided in the customer area, or you can choose to pay and have it done for you as a custom modification
Jakub03 Posted December 17, 2013 at 04:46 AM Author Posted December 17, 2013 at 04:46 AM Awesome thanks! Do you know of any place where i can find those backgrounds for commercial use? I was looking for some gambling related ones.
Ehren Posted December 17, 2013 at 05:44 AM Posted December 17, 2013 at 05:44 AM Just sent you a PM with some links
Jakub03 Posted December 17, 2013 at 07:25 AM Author Posted December 17, 2013 at 07:25 AM Thanks for the links! What are the dimensions of the icons in the navigation bar?
Ehren Posted December 18, 2013 at 12:04 AM Posted December 18, 2013 at 12:04 AM They are meant to be 16x16, but some are wider at 17x16. Either size is fine
