Loky Posted January 10, 2013 at 05:26 PM Posted January 10, 2013 at 05:26 PM Hi there, Can ayone tell me if there are some big diferences between 3.3.x and 3.4.x skins? Can I still use the old skin or I have to upgrade? I'm asking this becaue I'm using the Baisik skin which I cusomized presst heavily. Thanks in advance for your answer.
Ehren Posted January 10, 2013 at 11:25 PM Posted January 10, 2013 at 11:25 PM Hi Loky, There are dozens of changed HTML files, and many new lines of css in 3.4.x. To avoid any potential issues, it's highly suggested that you use the latest version of the skin. You can use the template merge center to create a "difference report" if you want to manually upgrade. Here's a basic tutorial on how to do that.
Loky Posted January 11, 2013 at 03:03 PM Author Posted January 11, 2013 at 03:03 PM Thanks for the reply. I'll start workiong then Have a great day!
