Slate Mobile Design with IP.Content
I've run into a problem in the mobile default skin for IPB where my site runs off IP.Content as the homepage/default. The problem is that there isn't any forum link in the Navigation Grid.
Does the Slate skin support a Forum, Store and Content (Homepage) link in the Navigation Grid?
The slate skin is based on the default mobile skin for IPB. If the default skin doesn't support it, Slate won't either. :unsure:
The latest version of Slate has a Store link, but apparently it shows for people even if they haven't got Nexus installed so I'll need to look into that. I'll update it in a few days and will try to add some basic support for IP.Content, but can't promise anything..
Cool. The issue I had was somewhat resolved by IPB support (and has also been raised as a bug to fix in the future), so I shouldn't have any problem with the skin.
This is the solution so it might be something to look at yourself:
ACP > Look & Feel > IP.Board Mobile > Global Templates > globalTemplate
Find;
<if test="hasMemberList:|:$header_items['applications']['members']['app_show']">
  <li id='nav_members'><a href='{parse url="{$header_items['applications']['members']['app_link']}" seotitle="{$header_items['applications']['members']['app_seotitle']}" template="{$header_items['applications']['members']['app_template']}" base="{$header_items['applications']['members']['app_base']}"}' title='{parse expression="sprintf( $this->lang->words['go_to_prefix'], IPSLib::getAppTitle('members') )"}'><span class='icon'></span>{IPSLib::getAppTitle('members')}</a></li>
 </if>
Replace with;
 </if>
 <if test="hasForums:|:$header_items['applications']['forums']['app_show']">
  <li id='nav_forums'><a href='{parse url="{$header_items['applications']['forums']['app_link']}" seotitle="{$header_items['applications']['forums']['app_seotitle']}" template="{$header_items['applications']['forums']['app_template']}" base="{$header_items['applications']['forums']['app_base']}"}' title='{parse expression="sprintf( $this->lang->words['go_to_prefix'], IPSLib::getAppTitle('forums') )"}'><span class='icon'></span>{IPSLib::getAppTitle('forums')}</a></li>
 </if>
That adds a forum link in the navigation box thing.
