Creaky Posted June 8, 2012 Posted June 8, 2012 I'm going to be buying either baisik or unifrom shortly but have a couple of questions. Header advert position. Where would adverts appear in the header of either style, do you have any screenshots? Both skins have text based logo's, I assume this can be changed to a image based logo For the uniform skin can the width be easily changed? Would it just be a CSS edit? Thanks.
Ehren Posted June 9, 2012 Posted June 9, 2012 Hello, 1. Both skins support the standard IPB ad positions. The "header" ad is inside the content area, below the breadcrumb navigation. 2. Yep - there's a tutorial in the customer area 3. Correct, it's just a css edit. Very easy to change. Hope that helps!
