Leo Tan Posted May 10, 2012 Posted May 10, 2012 Hi, I check out the pages of your ip.content and I wish to know if I purchase the gravity (blue), will the side boxes' theme be the same or it wouldn't be changed? As I hoping that it will change the boxes. Attached is a picture of my site's ip.content side boxes, which I wish to be changed to your design. If it can be done, is it as simple as just uploading your theme and it will be changed automatically or I need to edit it? My website is www.sghamsters.com
Ehren Posted May 11, 2012 Posted May 11, 2012 Hello, The 3.2.x and 3.3.x skins have full support for IP.Content.
Leo Tan Posted June 20, 2012 Author Posted June 20, 2012 I just reinstall my ipb and ip.content. And the side menu appears differently. Can it be fixed?
Ehren Posted June 20, 2012 Posted June 20, 2012 The skin needs to be installed after IP.Content. If you recently installed IP.C, you'll need to reinstall the skin.
