After a few solid days of work, all skins have now been upgraded to 3.3.x.
Current customers can download the upgraded skins for free from their client area, with the option to donate if you're feeling generous :)
  • Like 11
Okay so have you updated the name, since the file name I download on my market place purchases, said 3.2 but it worked, just confirming
Thank you kindly!
:thumbs:
The marketplace files are not yet updated. PM me with your IPS username and I'll upgrade your account on these forums.
Thanks Ehren, a donation for a beer is headed your way. :)
Thanks bud :)
Fixed - and files have been updated in client area.
Nice one, thanks!
Any idea when the new skins will be available or perhaps a teaser of what they are like?
I have a few psd files on my computer, but won't be able to code them into skins until the custom skin (and skinbox) queues have been finished. Might post some screens later.
Thats cool, but some screens would be great! :D
I tried uploading Chameleon.... It gave me warning the skin is of 3.2 though i downloaded the 3.3 links... and I tried twice.... if the staff can look into it...
Post a screenshot of the error (in the customer area) if you can. Thanks :)
New updates will be released tomorrow with some bug fixes included. It's not a critical upgrade, but some skins will benefit :)
  • Like 2
Like Uniform and the Forum View? I tried to fix the <<<, <<< issue but I ended up breaking the skin, haha.
Thanks for the update. :)
Yep - that's all fixed (and will be released soon in the customer area). :)
All 3.3.x skins have been updated with bug fixes (anything mentioned in the bug forum should now be fixed). Any template files which missed the upgrade (causing incorrect text, missing links, etc) have all been updated correctly in the latest skin files (which are hopefully all bug-free now). :)
Ahh, forgot about that! Nothing critical so I'll try to fix it for the next update.
Its not but if you work out a fix before then, I'd really appreciate it if you could post it so I can apply the fix :)
