Ant_ Posted September 7, 2011 Posted September 7, 2011 Ello just a presales question. If i was to buy this skin would it be easy to.. #1 move the user_bar down to beside the toggle_search to it's left so it becomes part of that section #2 with the extra space created from the user_bar being moved, center the main logo in that branding section and increase the pixel size to 200 any info would be great cheers
Ehren Posted September 7, 2011 Posted September 7, 2011 Hello, I probably wouldn't suggest moving the user bar down next to the search area. Depending on the amount of links you have, there isn't much spare room in the 3.2.x version. Screenshot attached to show you what it's like on my development board: If any of your members have semi-long usernames (or if they haven't validated their account), the user bar section becomes even longer. It's definitely possible (and quite easy) to increase the height of the logo if needed.
