JK.NK Posted August 28, 2011 Posted August 28, 2011 Hi, I am interested in purchasing Engrave. I have a few question though: 1. Can you tell me the maximum size I can have my header? I like big headers 2. After purchasing, can you help me adding a new tab on the forum, members line so that it looks the same as the rest and have it appear last? If this is an additional cost, how much will it cost? 3. My old skin is a light skin. Engrave is a dark skin. Is there a way to change the color of the posts for old post? For example, any post made in black is changed to white? Thank you. JK.NK
Ehren Posted August 28, 2011 Posted August 28, 2011 Hello, 1. You can easily edit the height of the banner, however keep in mind that the user info (Login, Register, Notifications, etc) is shown in the header so you will need to take this into consideration when modifying the skin. 2. Adding new links is simple and I'll be happy to help if needed. 3. Any previous posts will automatically inherit the new style, so it doesn't matter if you have previously used a light skin.
