IamFreddyG Posted August 24, 2011 at 04:01 PM Posted August 24, 2011 at 04:01 PM I was wondering if you have anything posted in the customer lounge on adding features to the skin. Like a background picker to one that doesn't have one or avatars in board index? Also if you don't would it be relatively cheap less than $75 to add those features to a pre-made skin? Thanks, Freddy
Ehren Posted August 25, 2011 at 12:12 AM Posted August 25, 2011 at 12:12 AM Hi Freddy, There are tutorials in the customer section which teach you how to make small/basic modifications to the skin (adding new backgrounds to Uniform, setting a default colour in Infinite, increasing the width of the author column, changing logos, etc). Major modifications, such as adding a background changer to any skin, are not provided as there's simply too much work to write in a tutorial (and the code would obviously vary between skins). I'll need to speak with my php developer about adding avatars to the forum index (I'll assume you meant forum index and not board index). I haven't done it in my 3.2 skins since avatars of the last poster are already shown.
IamFreddyG Posted August 27, 2011 at 12:15 PM Author Posted August 27, 2011 at 12:15 PM Ok thanks, Would you do freelance to add a major modification like a background changer to a skin that doesn't have one? How much would that be or you don't provide that at all? Thanks, Freddy
Ehren Posted August 28, 2011 at 06:17 AM Posted August 28, 2011 at 06:17 AM Hi Freddy, It's possible if needed. Custom work is priced at $60/hour. Can't really give specifics on how long it took to add the background changer, but it would be less than an hour.
