vilgent Posted August 2, 2011 Posted August 2, 2011 Hey all, I figured since this was the general discussion I could ask this here (lost my IPB password and they're taking a long time to e-mail me a new one). I've created various groups, each with their own permissions (and color-coded). That all works fine. However, when you look at the "last reply" portion with their name, the color is not there. Also, when you go into a specific board and see all the author names, none of them are their corresponding group's color code. For instance, in picture one you'll see three posts - none of the authors are color-coded - but if I click on Assassin's profile (the first 'last reply' author), you'll see his group is colored correctly. So, my question: how do I make it so their group's color code in the last reply and author sections? I assume they're part of the same feature, but I've had no luck finding where to fix it. phpBB did it by default (what I came from). Thanks for the helP!
vilgent Posted August 2, 2011 Author Posted August 2, 2011 I also want to add that the groups have the correct coloring when you're viewing who's online.
Steve H Posted August 2, 2011 Posted August 2, 2011 You would need to download something like this. http://community.invisionbyte.net/forum/48-tb-group-format/ However I don't believe he has updated it to work with 3.2 yet so at the moment there is very little you can do.
