Mt. Nick Posted July 26, 2011 Posted July 26, 2011 Hello, There is a bug in baisik. - http://screensnapr.com/v/akRrKi.png - It is off Another one - http://screensnapr.com/v/Vlq0hZ.png - It is off Yet another bug (In Blog) - http://screensnapr.com/v/COO14O.png - Tiny square light grey out of the blue. Reporting a blog - http://screensnapr.com/v/zGpBMs.png - Way off! Reporting a thread - http://screensnapr.com/v/TunmVy.png - Somewhat off. Reporting gallery picture - http://screensnapr.com/v/20PL22.png - Off. Reputation is off in profile - http://screensnapr.com/v/2ycBEK.png
Steve H Posted July 26, 2011 Posted July 26, 2011 Honestly I think you're being a little pedantic. Half of these so called issues are also present in the default IP.Board skin.
Mt. Nick Posted July 26, 2011 Author Posted July 26, 2011 Honestly I think you're being a little pedantic. Half of these so called issues are also present in the default IP.Board skin. Still the designer has to fix them, IPB isn't going to fix the designs the designer has made.
Steve H Posted July 26, 2011 Posted July 26, 2011 Did you even read what I wrote? The issues are present on the default IP.Board skin - the one released by IPS. Lookup pedantic since you've glanced over that word.
nodle Posted July 26, 2011 Posted July 26, 2011 If they are present on the default IPB skin, it's not Ehren's fault and will be up to IPB to fix them first. Just like Steve said.
The Heff Posted July 26, 2011 Posted July 26, 2011 There's no need to throw insults. The OP spotted some bugs and reported them. I'm sure Ehren would prefer bugs be reported than not, just to be safe... Better safe than sorry. 1
Ehren Posted July 27, 2011 Posted July 27, 2011 Textarea's are simple to fix. I'm not sure what the issue is with the second screenshot. Everything seems to look as intended. The tiny square blog issue isn't happening for me. The tooltips are generated automatically by javascript. If I repositioned that tooltip to center it, all other tooltips would be out of alignment. This will most likely be an issue with all IPB skins, not just mine.
Ehren Posted July 27, 2011 Posted July 27, 2011 All of the report center textarea sizes are fixed (on my development board, not the demo board) and will be available in a future update. But yes, these were bugs with the original IPB skin (which I did not create). They have been fixed regardless. Always good to have a bug free skin.. 1
Mt. Nick Posted July 27, 2011 Author Posted July 27, 2011 All of the report center textarea sizes are fixed (on my development board, not the demo board) and will be available in a future update. But yes, these were bugs with the original IPB skin (which I did not create). They have been fixed regardless. Always good to have a bug free skin.. Always good to be a step ahead
