Fischje Posted May 25, 2011 at 01:46 PM Posted May 25, 2011 at 01:46 PM Hi There! Our small community Site is working with Joomla and phpBB3 choosing a lightly improved skin from rocketthemes. Now, that IP.Content is there I think of changing to IPB, because of stability, Social-connections and of course the ability to make some sites around the board with content on it. In think my Skin is realy nice so i probably want you to skin my current theme for ipb. The Questions i have before that are: 1. Is it possible for you to take my skin to ipb. and slightly refresh it, so it looks a bit better (for blog, downloads, content, calender and so) 2. Is the skin ready for IPB 3.2, as you said to an other customer IP.Content will be supportet with 3.2 3. Language? German? My currently Site is located at: www.thekenbrasilianer.de Forum at www.thekenbrasilianer.de/forum
Ehren Posted May 26, 2011 at 01:21 AM Posted May 26, 2011 at 01:21 AM Hello, Skins will only support IPB 3.2 when that version is released. It's not possible for me to make a skin for 3.2 until I have a version of my own to play with. When it is released though, all new skins will be compatible (and old ones after they're upgraded). Languages can be changed very easily with IPB. Most buttons are controlled by HTML text rather than images which means you can change from English to German by simply installing the German language pack. Happy to redesign the skin slightly aswell if need be. I should note that I've had trouble integrating the Rockettheme dropdown menu since it's based on mootools. There always seem to be javascript incompatibilities arise when I add mootools to work simultaneously with prototype - so that might be the only issue. Normally the clients are happy with just a css based menu (it works the same as the javascript one, but there's no "slide" animation).
Fischje Posted May 26, 2011 at 06:59 AM Author Posted May 26, 2011 at 06:59 AM Thank you for your quick reply! The mootools based menu is no must have for me.
Ehren Posted May 26, 2011 at 07:03 AM Posted May 26, 2011 at 07:03 AM I can have it as close as possible, but I just don't think I'll be able to get the animation to work. Will google it later if I ever need to do it. Feel free to contact me after the 3.2 release if you need the skin done.
Fischje Posted May 26, 2011 at 09:55 AM Author Posted May 26, 2011 at 09:55 AM Thank you very much! I will make some changes to the skin at a .psd and write down my must-haves from function that i want for your skin and then contact you. I hope 3.2 will be released soon.
