Smilie Posted March 2, 2011 Posted March 2, 2011 Hi, Do you provide a service converting a fixed skin to a fluid (imperial), if so, how much does it costs? 1
Ehren Posted March 2, 2011 Posted March 2, 2011 It's a very simple edit and can be done for free. Instructions are provided if necessary so you can do it yourself
Smilie Posted March 2, 2011 Author Posted March 2, 2011 Will it look the same? I mean, I dont want stretched images or something in that way.
Smilie Posted March 2, 2011 Author Posted March 2, 2011 Skin purchased, please post instructions Also, is it possible to disable the sidebar?
Ehren Posted March 3, 2011 Posted March 3, 2011 Feel free to use the customer area for any support or modification questions.
