Ehren Posted January 12, 2011 Posted January 12, 2011 Hi everyone, Just a quick announcement to let all current customers know that all premade skins have been upgraded to be compatible with Blogs 2.3.1, Chat 2.3.0 and Nexus 1.1.1 2
AWS Posted January 12, 2011 Posted January 12, 2011 I am amazed at how fast you get these updates done. 1
Christixn Posted January 12, 2011 Posted January 12, 2011 Thanks Ehren! But what's are changed at the blogs? I thought it was a maintance update or something..
Ehren Posted January 12, 2011 Author Posted January 12, 2011 Blogs don't actually have any new templates as far as I know, but some of the skins have a cleaner design compared to the first 2.3.0 release 1
nodle Posted January 13, 2011 Posted January 13, 2011 Hey there Ehren, can you take a look at this on your dev board, I noticed that this part when you hover "Popular products" it disappears. It's for Nexus. Also the: #store_wrapper .filter a.active { background: none repeat scroll 0 0 #333333; color: #FFFFFF; padding: 5px 8px; } may need to be lightened up so you can see which one is selected.
Ehren Posted January 13, 2011 Author Posted January 13, 2011 Updated versions will be re-released with some blog design updates over the next few hours.
Ehren Posted January 13, 2011 Author Posted January 13, 2011 Ok, all skins re-updated with a neater blog layout. Took all day, but it's definitely much better for anyone who uses the blogs.
IanW Posted January 13, 2011 Posted January 13, 2011 just installed the overlay blue as a test skin and gone to the blogs and it looks identical to the previous versions. Sorry.
Ehren Posted January 13, 2011 Author Posted January 13, 2011 Post in the support section if you need any help.. the skin on my development board was updated and that same skin was exported/added to the customer area. Make sure you're using the new skin too and not the old files accidentally.
devee Posted January 13, 2011 Posted January 13, 2011 Would be very nice if you could post the skin modifications for Checkered from IP.Blog 2.3.0 to 2.3.1 since I did my big update the day before the release of IP.Blog 2.3.1. Best regards, devee
nodle Posted January 14, 2011 Posted January 14, 2011 Your probably busy Ehren but when you get a chance can you check out the Nexus skin problem that I posted up top? Check it out on your dev board, you will see what I mean.
