Unfortunately one of my admins somehow wrecked our calendar while I was gone and tried to completely delete it and reinstall it but it did not work. The calendars tables are missing from the database and the files also. Now I tried to copy these files and tables from a working forum but that didn't work. When I try to upgrade the installer says it can't be installed.
So my question is how can I reinstall the Calendar into IPB?
Wow I've never actually heard of that happening. Might want to check over at the Invision forums for an official answer. :)
I'd assume it's somehow possible to reinstall..
Thought so, i was surprised too. And since i couldn't find anything on this i thought i ask here. I will ask support then I hope they have some usefull ideas. ;)
Okay I feel just dumb now :lol:
I copied the calendars files in to the wrong directory ofc...
So if someone else runs in to the same problem:
The install files of your calendar should be in /admin/applications_addon/ips/calendar and here ONLY
i wasn't sure the first time so i copied it in the applications folder and in the applications_addon/other folder too, which was a realy stupid idea, I deleted the files from the wrong directories and refreshed the apllications page in the admin panel and voilà the status of the Calendar changed from Cannot Install to Install
