I just got excited when i noticed that the skin was upgraded to 3.1
i had few questions about it
is it compatible with 3rd party applications i am planing on using video system on it LINK
and may i get a live demo of it if u provide
many thanks
The skin will work with all modifications - just like any other skin. However you may need to do a few slight adjustments (rounded corners, thick borders, etc) to make the skin look perfect. These adjustments aren't essential since the mod will work just fine, however there may be a few sections that look a little odd since the skin doesn't support the mod by default.
A service which fully updates your skin to make it integrate perfectly is available for an additional $30.
i will first see how it goes without the adjustments (i did see other forums were using the same skin with other mods on it it looked perfect) awesome skin by the way. thanks i am gonna purchase it
