@Ehren,
\i have a weird question for you if i don't have ipb 3.1 or early version and use vbulletin how much would u take to convert it over to the forum software so i can use your skins their?
awaiting for carbon blue :D
EDIT: Where am I meant to download it from when ready?. I can't seem to access the customer's only download section.
ok well can u do a custom skin for vbulletin then or wont do that either?
I don't do any work for vBulletin since I've never used it before. I'm happy to refer you to someone if you need a vbulletin skin made though :)
PM me and let me know of your paypal address and what skins you've purchased and I'll upgrade your account for you so you have access. Anyone who purchased before November 2009 will need to be upgraded manually.
Baisik completed. Suggestions for next upgrade?
I was hoping you'd work from the group up. Starting with Deflection. :unsure:
Was Carbon Blue finished? In my downloads section I see "Carbon Blue 3.0.5 + psd Files" so I'm guessing no?
No, carbon has not yet been done.
Carbon blue please :)
I second the Carbon Blue suggestion :)
Yes!
Yes, Carbon Blue! :)
carbon blue!!!!!!
Carbon blue 3.1.x is now available. Green, red and orange coming next.
Aren't you worried about 3.1.1?
What are they changing something major, or is it just coming out soon where the skins will have to be re-written again?
There will just be additional bug fixes required.. I don't think there will be too many though since a majority of the bugs were fixed back in 3.0.x
Ah I see thanks for the update Ehren! ^_^
