Maik Posted March 3, 2010 at 08:17 AM Posted March 3, 2010 at 08:17 AM Hi, we want to buy a skin from your site. Before we can, we have to know, if we can use Your skins with our IPB 3.0.5 in german language. Or will there be problems with other languages than english? Thank You! Maik Edit: Sorry for the wrong placement of my question, please move to the right one
Ehren Posted March 3, 2010 at 01:09 PM Posted March 3, 2010 at 01:09 PM Hello, Other languages have not been tested with some of these skins, although all left-to-right languages should work fine though since none of the coding is affected. The only languages that may disrupt the design are right-to-left languages.
juanito Posted March 5, 2010 at 02:02 AM Posted March 5, 2010 at 02:02 AM I take the thread to ask if these skins can get to do this, is a skin which when used with some broken Spanish language modules: Can their skins get to do the same? Could you fix it? Can your skin change in the width of the sidebar so that the modules are not broken? thanks in advance
Ehren Posted March 5, 2010 at 02:58 AM Posted March 5, 2010 at 02:58 AM Hello, If that issue occurs on one of my skins once you purchase, I'm happy to help you solve it.
juanito Posted March 5, 2010 at 09:52 AM Posted March 5, 2010 at 09:52 AM many thanks for the attention and response so fast.
