Eternal Posted February 12, 2010 Posted February 12, 2010 Just wondering when designing site navigation (wanting to add a bit of animation), would you recommend javascript or flash? I'd normally do flash, but realize not everyone likes to enable Flash.
Ehren Posted February 12, 2010 Posted February 12, 2010 Depends what sort of animation. Many animated effects can be easily achieved with jQuery (which is definitely much better compared to flash in my opinion). I'd go with javascript.
Eternal Posted February 12, 2010 Author Posted February 12, 2010 Is jQuery better then javascript? It would e similar to this type of animation (just highlighting buttons when hovering): http://bleachgaming.com/
Ehren Posted February 12, 2010 Posted February 12, 2010 jQuery is javascript. You can do hover effects like that just with css, so you don't need any jquery effects for that navigation.
Sebastien Penet Posted February 13, 2010 Posted February 13, 2010 Hum, I'd say you should avoid Flash as often as possible. As you may know, some mobile devices don't support it, mostly for performance reasons. However, most recent devices support javascript. For example, the iPhone/iPad aren't likely to support Flash in a near future. And there are more users than we imagine
Eternal Posted February 15, 2010 Author Posted February 15, 2010 While we're talking about navigation on my site... just wanted to see which type of table borders people preferred: or:
Ehren Posted February 15, 2010 Posted February 15, 2010 Don't like the angled one.. straight seems better to me.
Eternal Posted February 26, 2010 Author Posted February 26, 2010 Just wondering Ehren is something like this possible? It would have a scroll then for the rest of the way like this: http://dragonballzocg.com/beta/
Nervosa Posted February 27, 2010 Posted February 27, 2010 Yes, its possible to design a layout like that. Also, Im not feeling that gray much, try pulling some colors from your background.
Eternal Posted February 27, 2010 Author Posted February 27, 2010 Yes, its possible to design a layout like that. Also, Im not feeling that gray much, try pulling some colors from your background. Your the first person so far that has said you didn't like the gray. =( So far everyone has loved the look. I did try colors from background, and it looks really bad, no one seemed to like it.
Simon Leufstedt Posted March 1, 2010 Posted March 1, 2010 That forum skin looks really nice and original. Maybe the forum is a bit too gray. But it could work, as its hard to tell from screenshots.
