ker Posted July 21, 2024 at 02:37 PM Posted July 21, 2024 at 02:37 PM i want to make a staff application inside my forums, for example there is questions then a box beneath to answer, then you have to submit if all fields are complete, im new to all of this. For example this https://cmgstudios.net/forums/index.php?/forms/8-staff-application/
Ehren Posted July 21, 2024 at 07:48 PM Posted July 21, 2024 at 07:48 PM You could potentially create something like that using the Pages application from Invision, but I don’t have a copy/paste solution which you can use since it would be a manual process. I believe the site you linked to is using an addon/application to create those forms, so you’d otherwise need to install that if you aren’t comfortable using the Pages app.
