Ricsca Posted October 31, 2021 Posted October 31, 2021 I'm considering a theme to buy for my forum. I like your illuminate theme but I wanted to know if you can add the information and groups as in the image that I am attaching under the avatars. Thank you
Ehren Posted October 31, 2021 Posted October 31, 2021 Hey @Ricsca Welcome to ipsfocus! I imagine an addon/plugin would be able to add those stats to the author column. It’s not something which comes with my themes by default, however if you find an addon which achieves that, you’ll be able to use it with illuminate. I hope that helps!
Ricsca Posted October 31, 2021 Author Posted October 31, 2021 This theme has these options and has not component.
Solution Ehren Posted October 31, 2021 Solution Posted October 31, 2021 Oh nice. You can display custom profile fields in the author column by visiting /admin/?app=core&module=membersettings&controller=profiles. I do this on these forums, however I just use plain text (no icons or anything). You'd be able to achieve a similar layout as your screenshot by using this in the "Custom topic formatting" setting: <div class='ipsFlex ipsFlex-ai:center ipsFlex-jc:center'> <span><i class="fa fa-bar-chart" aria-hidden="true"></i> {$title}</span> <span>{$content}</span> </div> As for other features (such as the member id or join date), they would require template modifications in the author column file, which is something I aim to avoid if possible since it can make upgrades complicated.
