Hello, we just updated from 4.5 to 4.6 on ipb as well as updating the theme. However there seems to be an issue related to our animate themed and the new achievement system. Instead of displaying a small icon around the profile picture it instead displays an enermous one above the profile picture. It will disappear and become a small one if i switches to a another theme. So it's theme related. Any ideas what can be done to resolve this, please let me know - arc
Picture of current theme
Picture of the issue
Picture of how we would like it to be
Hi Arcadiez,
If you've purchased the theme from the Invision marketplace, please send me a PM with your username so I can upgrade your account to Customer status. If you can also please update your Forum URL so I can view your issue myself, that would be great! It's currently set to "Double Bubble Canapy" which isn't a valid URL :)
Thank you!
1 hour ago, Ehren said:
Hi Arcadiez,
Thank you!
Woops my bad, appearntly copied and paste something different than the intended url; Has been updated.
Correct, the theme was bought from the marketplace, but not under my name as im not the owner of the website. If you need receipt or other related information you have to wait a bit until he wakes up and i can gather the info.
I'm an Adminstrator and as well responisble for GFX related stuff, so the new achievement rank system is under my responisblity. Spend like an hour yesterday after the update googling and searching if there was any specific option to change the location of the new rank system until i figured out it was the theme itself who caused it. Would appreciate if you can help finding a solution without having to change theme.
Thank you - arc
Have you modified the HTML code of any template files? Your Animate theme is using modified code for the author column.
The Animate theme on my demo board is working correctly, so I'd suggest reverting any template files which you've modified to see if the issue fixes itself :)
