Current theme differences for 4.6.5.1
core → front → global → footer
core → front → global → globalTemplate
core → front → global → logo
core → front → global → mobileNavBar
core → front → global → mobileNavigationIcon
core → front → global → navBar
core → front → global → userBar
Went to update, but stopped due to this.
9 hours ago, Rspin said:
Dear sirs!
I have some changes to the old theme. Will I lost them after update?
This is a little tricky to answer. It's best to avoid template changes if possible, and only use custom.css to make your modifications. If this isn't possible, installing your theme as a parent, and then creating a child theme (and using/modifying that) would be ideal.
If you're already using a 4.6 version of the theme and are upgrading your software to 4.6.5.1, there are no theme updates needed. :)
  • Like 3
  • Ehren locked this topic
