Vhero Posted August 31, 2009 at 03:09 PM Posted August 31, 2009 at 03:09 PM does this skin come with an option to make fluid.
Ehren Posted August 31, 2009 at 11:57 PM Posted August 31, 2009 at 11:57 PM Not exactly an option as such, but once you install the skin you can very easily change it to a fluid design by editing the css.
xe-cute Posted October 14, 2009 at 02:31 PM Posted October 14, 2009 at 02:31 PM I'd like this in fluid too, if it is up to date with 3.0.4 skin edits too. I think it is a simple case of altering the fixed width in pixels to a percentage such as 98% or whatever you would like Vhero, so pretty easy to do.
Ehren Posted October 14, 2009 at 10:45 PM Posted October 14, 2009 at 10:45 PM Yep - that's correct.. It's just the singe css change.
