kobayashi90 Posted November 6, 2020 at 12:36 AM Posted November 6, 2020 at 12:36 AM does Deflection 4.5.4 it support Invision 4.5.4 or not, you should try to declarate that on the changelog. thank you.
Ehren Posted November 6, 2020 at 01:51 AM Posted November 6, 2020 at 01:51 AM Hello, Yes, the version numbers of the theme have purposely been chosen to match the version number of the software. The matching numbers are no coincidence. With that said, the 4.5 themes have been coded with minimal template file modifications, which generally means that they'll work on any 4.5.x version of the software. 1
