Ehren Posted July 28, 2020 Posted July 28, 2020 Hi everyone, With more progress being made each day on the 4.5 themes, I'd like to show another sneak peak of a new feature which will be included with all themes: a switch for light/dark modes. This button will allow your members to easily switch from a light theme to a dark theme, and vice versa. This can be used to switch between any two themes, for example: - You can use it to switch between light and dark versions of the same theme like Chameleon and Chameleon Dark - OR - You can use it to switch between any light or dark ipsfocus theme, such as Ortem and Carbon This feature is easily enabled, disabled and customized via the theme settings in your ACP. Note: This feature is technically limited to customers who own at least two ipsfocus themes. Make sure to check back over the next couple of days for sneak peaks of more new features! 7 1
uA_Y_C_A Posted July 29, 2020 Posted July 29, 2020 If we have the current Uniform theme, which theme should we buy for dark mode?
Ehren Posted July 29, 2020 Author Posted July 29, 2020 23 minutes ago, uA_Y_C_A said: If we have the current Uniform theme, which theme should we buy for dark mode? Any dark theme from this site will work. I plan on creating some "dark mode" styles for existing themes at some stage, and Uniform Dark will likely be included. 2 1
The Heff Posted July 30, 2020 Posted July 30, 2020 I'm really looking forward to this feature (and being able to stop repeatedly telling people how to switch theme!) 1
Freddie M Posted July 30, 2020 Posted July 30, 2020 I love it @Ehren, how does it look in the responsive side of things? Really can't wait to upgrade [well I must] but your themes are a big part in me changing my mind from sticking with 4.4 for awhile.
Ehren Posted July 31, 2020 Author Posted July 31, 2020 4 hours ago, joey_m said: I love it @Ehren, how does it look in the responsive side of things? Probably just as you'd imagine
uA_Y_C_A Posted July 31, 2020 Posted July 31, 2020 On 7/29/2020 at 11:01 AM, Ehren said: Any dark theme from this site will work. I plan on creating some "dark mode" styles for existing themes at some stage, and Uniform Dark will likely be included. It would not be nice to have too many changes in the theme as the name is "switching to dark mode". Either i need to choose the one closest to the uniform or wait for the uniform dark to come out. For example Engraved, Deflection or Brave.
uA_Y_C_A Posted August 12, 2020 Posted August 12, 2020 On 7/29/2020 at 11:01 AM, Ehren said: Any dark theme from this site will work. I plan on creating some "dark mode" styles for existing themes at some stage, and Uniform Dark will likely be included. Hello Ehren, Will the "Uniform Dark" theme come out with the 4.5 final? or 4.5.1 Thank you
Ehren Posted August 13, 2020 Author Posted August 13, 2020 20 hours ago, uA_Y_C_A said: Hello Ehren, Will the "Uniform Dark" theme come out with the 4.5 final? or 4.5.1 Thank you Let's go with 4.5.0 2
uA_Y_C_A Posted August 13, 2020 Posted August 13, 2020 4 hours ago, Ehren said: Let's go with 4.5.0 Thank you
AnonyWS Posted August 22, 2020 Posted August 22, 2020 Oh damn thought the theme had a dark version aahah
Ehren Posted August 22, 2020 Author Posted August 22, 2020 2 hours ago, AnonyWS said: Oh damn thought the theme had a dark version aahah Dark versions of themes will arrive once the existing themes have been upgraded
Uncrowned Posted August 24, 2020 Posted August 24, 2020 This might be my favorite 4.5 feature announcement and it is not even from IPS. 1
