On 5/27/2019 at 2:06 AM, Ehren said:
4.4.4 is only in beta. Themes will be upgraded once the final version of 4.4.4 is released :)
True! Sorry!
4.4.4 is out now, and Chameleon Dark is being flagged as incompatible due to the following:
core → front → widgets → guestSignUp
Patience. Version 4.4.4 has come out today and I'm sure @Ehren will soon offer it to us. 😉
Oh, of course - just wanted to post it in case anybody else using this excellent skin is eager to upgrade to 4.4.4 😃
Can't you just revert it to the default?
Actually that will mess up the styling. Looks like the update template is:
{{$buttonMethods = $login->buttonMethods();}}
{{$usernamePasswordMethods = $login->usernamePasswordMethods();}}
{{if $orientation == 'vertical'}}
	<div class='ipsWidget_inner ipsPos_center ipsPad'>
		<div class="ipsAreaBackground_light ipsPad">
		    <h2 class="guest-widget-header">{$title}</h2>
            <div class="ipsType_richText ipsType_contained">
                {$text|raw}
            </div>
		    {{if $buttonMethods}}
		        	<form accept-charset='utf-8' method='post' action='{$login->url}' data-controller="core.global.core.login">
						<input type="hidden" name="csrfKey" value="{expression="\IPS\Session::i()->csrfKey"}">
						<input type="hidden" name="ref" value="{expression="base64_encode( \IPS\Request::i()->url() )"}">
			{{endif}}
            <div class='guest-widget-footer'>
		            <ul>
		            	{{if $usernamePasswordMethods}}
			                <li>
			                    <a href='{url="app=core&module=system&controller=login" seoTemplate="login"}' class="ipsButton ipsButton_primary ipsButton_verySmall ipsPos_right">{lang="sign_in_short"}</a>
			                </li>
			                {{if \IPS\Login::registrationType() != 'disabled'}}
				                <li>{lang="or"}</li>
				                <li>
				                    <a href='{url="app=core&module=system&controller=register" seoTemplate="register"}' class="ipsButton ipsButton_primary ipsButton_verySmall ipsPos_right">{lang="sign_up"}</a>
				                </li>
				            {{endif}}
		                {{endif}}
				            {{foreach $buttonMethods as $method}}
					            <li>
					                {$method->button()|raw}
					            </li>
				            {{endforeach}}
				        {{endif}}
		            </ul>
		    </div>
		    	</form>
		    {{endif}}
		</div>
	</div>
{{else}}
	<div class='ipsWidget_inner ipsPos_center ipsPad_half'>
                {$text|raw}
            </div>
			{{endif}}
		            <ul>
			                <li>
			                </li>
				                <li>
				                </li>
				            {{endif}}
		                {{endif}}
					            <li>
					            </li>
				            {{endforeach}}
				        {{endif}}
		            </ul>
		    </div>
		    	</form>
		    {{endif}}
		</div>
	</div>
{{endif}}
