• 0
Sign in to follow this
Dean_
Titan theme, using transparent section title from Uniform
Question
Hi Ehren,
Can this be done via simple css methods? Just making my final decision on a new theme and looking at things that can be done/changed?
Also do you still run the $5 off additional theme?
Thanks
Share this post
Link to post
Share on other sites
5 answers to this question
  • 0
Hi Dean,
The transparent effect in Uniform is actually a fake transparent effect, since it isn't possible to actually cut out elements using css.
The effect only works if the background of the site is a fixed image, covering the entire background:
background-size: cover;
background-attachment: fixed;
Titans background is usually static and has a gradient overlay, so for the effect to work, we'd need to remove the gradient and make the background fixed.
Since Titan is a little more heavy on effects compared to Uniform, the transparent category headers might increase the amount of scroll lag.. I'd only suggest doing the effect if absolutely necessary :)
And yep, the $5.00 discount is still offered for existing Customers. The price should be $25.00 for you instead of $30.00 :)
Share this post
Link to post
  • 0
Hi Ehren, this wasn't the case on my purchase of Titan.
Share this post
Link to post
  • 0
Apologies for that - I assumed you had purchased a 4.x theme already due to your Customer status. I didn't realise it was a 3.x theme.
The discounts apply for customers who have an active 4.x theme. If you check the prices on the main site now, they should be discounted to the $25.00 price. This discount will be applied as long as you have an active 4.x theme.
To apologise for the confusion, I've added $5.00 worth of credit to your account, which you can use for renewals or another theme. :)
  • Thanks 1
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Answer this question...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
