Canal World Posted April 14, 2017 at 08:39 PM Posted April 14, 2017 at 08:39 PM Hi, We may consider upgrading to IP.Board 4.2 when it's released. Will the Shift theme be compatible with this? If not, do you know roughly when it will be? (assuming IP.Board is released in mid 2017 as planned) Cheers
Empire Posted April 14, 2017 at 09:09 PM Posted April 14, 2017 at 09:09 PM I rather wait until all plugins and themes and whatnot be updated and supported
Alexander Scott Posted April 14, 2017 at 10:34 PM Posted April 14, 2017 at 10:34 PM 1 hour ago, Canal World said: Hi, We may consider upgrading to IP.Board 4.2 when it's released. Will the Shift theme be compatible with this? If not, do you know roughly when it will be? (assuming IP.Board is released in mid 2017 as planned) Cheers No. That theme and all the others will be need to be made compatible since there's a lot of changes in IPS 4.2 You will also most likely have to do a fresh install of your theme at that time. Also I would take Empire's Advice. It's better to upgrade until a lot of add ons and themes are made compatible for 4.2.x
Claire Posted April 15, 2017 at 09:08 PM Posted April 15, 2017 at 09:08 PM Quote Version 4.2 also features a refreshed AdminCP and default front-end design. Theme changes in 4.2 are mostly in the CSS framework so your existing themes will either work without issue or require minor changes to work in the new version. From: https://invisionpower.com/news/ips-community-suite-42-coming-soon-r998/
Ehren Posted April 15, 2017 at 11:44 PM Posted April 15, 2017 at 11:44 PM All themes will be upgraded to 4.2 and should only require minor css upgrades. It shouldn't be a very long process 3
