liquidfractal Posted April 9, 2017 at 01:52 AM Posted April 9, 2017 at 01:52 AM Hello, I've been browsing your skins, which look great! I notice that on some of your live demos (e.g. Chameleon) some of the switchable backgrounds are static images, and others scroll with the page. So in Chameleon, the first two background image options scroll, the third one is static, and the fourth is just a uniform colour. My question is: can one set the individual background images as either static or scrolling in the theme options? I'm particularly interested in having a static background image. Thanks!
Solution Ehren Posted April 9, 2017 at 02:57 AM Solution Posted April 9, 2017 at 02:57 AM 1 hour ago, liquidfractal said: Hello, I've been browsing your skins, which look great! I notice that on some of your live demos (e.g. Chameleon) some of the switchable backgrounds are static images, and others scroll with the page. So in Chameleon, the first two background image options scroll, the third one is static, and the fourth is just a uniform colour. My question is: can one set the individual background images as either static or scrolling in the theme options? I'm particularly interested in having a static background image. Thanks! Hello, Yep, it's very easy to change the scrolling behavior of each background image. The ones in the demo are simply examples of what's possible
liquidfractal Posted April 9, 2017 at 02:59 AM Author Posted April 9, 2017 at 02:59 AM Just now, Ehren said: Yep, it's very easy to change the scrolling behavior of each background image. The ones in the demo are simply examples of what's possible Awesome! Thanks for your quick reply Ehren - now all I have to do is try and decide which theme(s) to buy BTW...a hopefully helpful suggestion: maybe a Features Chart for your themes so that people could see at a glance which themes have Mega Footers, which have animations, etc. That said, you have some great themes here! Can't wait to start working with them! 1
Ehren Posted April 9, 2017 at 05:08 AM Posted April 9, 2017 at 05:08 AM 2 hours ago, liquidfractal said: BTW...a hopefully helpful suggestion: maybe a Features Chart for your themes so that people could see at a glance which themes have Mega Footers, which have animations, etc. There's a table at the bottom of each theme page which lists all of the theme features 1
liquidfractal Posted April 9, 2017 at 05:25 AM Author Posted April 9, 2017 at 05:25 AM That'll teach me for not scrolling down thanks again! 1
