tomk Posted October 17, 2016 Posted October 17, 2016 4.1.16 is out, have not looked at template changes, should we hold off or is it safe?
Smooth Posted October 17, 2016 Posted October 17, 2016 I think it's safe, I am tempted to just backup my website as it is currently, upgrade, and if it's stuffed, I'll revert
Empire Posted October 17, 2016 Posted October 17, 2016 There are CSS changes https://invisionpower.com/index.php?app=core&module=system&controller=plugins&do=diff You can upgrade it yourself or wait till @Ehren uploads the new version 1
The Heff Posted October 17, 2016 Posted October 17, 2016 There are new templates, so I'll definitely wait for Ehren to do the updates. 1
Tracy Perry Posted October 18, 2016 Posted October 18, 2016 This is the one thing I absolutely HATE about IPS. I really wish they would get a template merge/history function working. I'm so used to XenForo and that feature I upgraded to the new version without even thinking. Luckily I backed my directory structure and DB (yes, I've learned) up prior to that if something is majorly messed up.
tomk Posted October 19, 2016 Author Posted October 19, 2016 Any ETA @Ehren on patched themes for 4.1.6?
tomk Posted October 19, 2016 Author Posted October 19, 2016 8 minutes ago, Ehren said: The themes are being worked on right now Awesome!!! Thank you @Ehren
ABGenc Posted October 19, 2016 Posted October 19, 2016 On 17.10.2016 at 9:05 PM, Empire said: There are CSS changes https://invisionpower.com/index.php?app=core&module=system&controller=plugins&do=diff You can upgrade it yourself or wait till @Ehren uploads the new version May be updates from Ehren is not enough. I will wait for the fix from IPS for the following issue ; https://invisionpower.com/forums/topic/433296-submitting-often-fails-on-4116/
