nogi Posted July 7, 2016 Posted July 7, 2016 I've been trying to find a dark theme that works with my site. The issue is when the IPS table helper is used, the alternative rows are unreadable as the background is too light (or text is too light). Do you have a dark theme that could cater for this? The example below is with the Trader Feedback app which uses the IPS table helper:
Solution Ehren Posted July 7, 2016 Solution Posted July 7, 2016 Hi nogi, If the app has been coded correctly, all of my themes will work automatically with it. If, for some reason, the rows are still white when you use one of my themes, I'll be happy to help you with a solution
nogi Posted July 7, 2016 Author Posted July 7, 2016 cool and how are they with the latest version of IPS 4.1.13.1?
Ehren Posted July 7, 2016 Posted July 7, 2016 They're always kept up to date with the latest version Currently bug-free on 4.1.13.1
nogi Posted July 7, 2016 Author Posted July 7, 2016 Cool, I'll give the Dark Chameleon a go. Is the save10 code still valid? Doesn't seem to work for me.
Ehren Posted July 7, 2016 Posted July 7, 2016 33 minutes ago, nogi said: Cool, I'll give the Dark Chameleon a go. Is the save10 code still valid? Doesn't seem to work for me. Whoops, thanks for the heads up! Should now be fixed
