tomk Posted July 5, 2016 at 12:12 PM Posted July 5, 2016 at 12:12 PM Yea, it's out, a bit surprised considering all the open bug reports against it, but hey, whatever. Do the themes need to be updated to handle 4.1.13? Looks like there are a bunch of core IPS changes that will affect themes and styling, so holding off until we get an official answer from @Ehren. Thanks!
Ehren Posted July 5, 2016 at 01:24 PM Posted July 5, 2016 at 01:24 PM There's a huge number of template changes - so definitely wait until the themes are updated. You'll likely experience issues (particularly with the messenger) if you upgrade your site while using an outdated theme. The updated themes will hopefully be available within 24 hours, give or take. 11
qubabos Posted July 5, 2016 at 03:06 PM Posted July 5, 2016 at 03:06 PM 1 hour ago, Ehren said: There's a huge number of template changes - so definitely wait until the themes are updated. Hopefully within 24 hours, give or take. Hopefully thx mate
Yumasaki Posted July 5, 2016 at 08:42 PM Posted July 5, 2016 at 08:42 PM I had a problem with the upgrade with table cms_blocks i don't see display change in spectrum
EnigmaPatrick Posted July 5, 2016 at 11:38 PM Posted July 5, 2016 at 11:38 PM 2 hours ago, Yumasaki said: I had a problem with the upgrade with table cms_blocks i don't see display change in spectrum Themes haven't been updated for latest version yet.
Neejrow Posted July 6, 2016 at 01:03 AM Posted July 6, 2016 at 01:03 AM Do we know if the 4.1.13 update makes the theme 'upload new version' option actually work? I saw in the changelog a mention of something about IPS being able to handle updates to modified files better or some such?
EnigmaPatrick Posted July 6, 2016 at 01:10 AM Posted July 6, 2016 at 01:10 AM 7 minutes ago, DigoAlmino said: Do we know if the 4.1.13 update makes the theme 'upload new version' option actually work? I saw in the changelog a mention of something about IPS being able to handle updates to modified files better or some such? I can't actually find anything on this, it may be worth testing but I personally wont as I don't have much faith in it working.
Neejrow Posted July 6, 2016 at 01:52 AM Posted July 6, 2016 at 01:52 AM 41 minutes ago, EnigmaPatrick said: I can't actually find anything on this, it may be worth testing but I personally wont as I don't have much faith in it working. https://invisionpower.com/release-notes/ 'Better handling of upgrades if files have been modified'
Ehren Posted July 6, 2016 at 04:46 AM Posted July 6, 2016 at 04:46 AM 2 hours ago, DigoAlmino said: https://invisionpower.com/release-notes/ 'Better handling of upgrades if files have been modified' They're referring to the suite upgrades, not theme upgrades
Neejrow Posted July 6, 2016 at 04:51 AM Posted July 6, 2016 at 04:51 AM 3 minutes ago, Ehren said: They're referring to the suite upgrades, not theme upgrades Ah damn. I'm quite keen to upgrade to 4.1.3, hopefully I'll be able to manage it. Got quite a few customised templates now.
Atrumcavus Posted July 6, 2016 at 06:03 AM Posted July 6, 2016 at 06:03 AM Probably shouldn't have, but last upgrade I merely updated, rather than re-uploaded, and it seemed to work fine for me. But I might be the exception.
