need to know
Hello
i m your client at skinbox.com (theme : mystic) .
finally my website forum has been update 4.x version ipb .
Well the theme mystic broken & dead . i must to buy again it for great custom .
my questions :
-Do will you remake theme mystic for 4.1.x ?
-If i will buy your theme (maybe Engraved)
i will can to edit Custom navigation links ? because i cant find it "The navigation menu in IPS.Suite 4.x can be customized under ACP > System > Menu Manager" , atm theme IPB . normal ?
thanks
There are currently no plans to upgrade Mystic, sorry about that.
The navigation links are controlled in your Admin Cpanel. Click the System tab on the left column and then select Menu Manager.
well i have problem , i m adding "external link" , type url : steam://connect/IP:port
it says : That type of URL is not allowed.
how i allow it ? thanks
I guess that's a restriction of the menu manager.. You could maybe add it manually via HTML edits, or you could add a valid link into the menu manager and replace it with the steam link using javascript.
