BuddahBoy Posted September 7, 2015 Posted September 7, 2015 Greetings - I just wanted to know if the "Upcoming Events" sidebar module shows in the same manner as it does in V4, shown below - other than that question, this is just would like to say that this is one super theme - thanks! All the bestRon
Solution Ehren Posted September 8, 2015 Solution Posted September 8, 2015 Hello, The sidebar widgets in Subway 4.x will display the same as the default theme, yes. I haven't modified them
BuddahBoy Posted September 8, 2015 Author Posted September 8, 2015 Thank you Ehren - one last thing is about the calendar. I'm pretty sure about the answer but was not able to test it out on the demo - when an event is listed in the calendar and the user hovers over the name of it on the calendar does the popup bubble still appear? Thanks again for taking the time. All the bestRon
Ehren Posted September 9, 2015 Posted September 9, 2015 Thank you Ehren - one last thing is about the calendar. I'm pretty sure about the answer but was not able to test it out on the demo - when an event is listed in the calendar and the user hovers over the name of it on the calendar does the popup bubble still appear? Thanks again for taking the time. All the best Ron Hi Ron, The theme behaves exactly the same as the default theme, no features have been removed. The only difference is the appearance (colours and layout).
BuddahBoy Posted September 9, 2015 Author Posted September 9, 2015 Thank you for taking the time to clarify this for me Ehren - I just had to make sure as it's a project and was asked for a response certain. Much appreciate it and the good work you do. Okay, off to grab me a Subway. All the bestRon 1
