Courtland Posted August 15, 2017 Posted August 15, 2017 That worked Ehren, thanks again, is there any way to keep the "Start Topic" button on the right after removing forums? Thanks.
Ehren Posted August 15, 2017 Author Posted August 15, 2017 1 hour ago, Courtland said: That worked Ehren, thanks again, is there any way to keep the "Start Topic" button on the right after removing forums? Thanks. Add this too: body[data-pagemodule="forums"][data-pagecontroller="index"] .ipsPageHeader{ justify-content: flex-end; } 1 1
Courtland Posted August 15, 2017 Posted August 15, 2017 Once again, thanks Ehren, the support here is tops. It worked perfectly. 1
DewDrop Posted August 16, 2017 Posted August 16, 2017 Hi @Courtland, It's also possible to remove "Page" header? Because I use pages in the front page to show some articles like news and in the header shows "News" Thanks! 1
DewDrop Posted August 16, 2017 Posted August 16, 2017 32 minutes ago, DewDrop said: Hi @Courtland, It's also possible to remove "Page" header? Because I use pages in the front page to show some articles like news and in the header shows "News" Thanks! Sorry, wrong person! Can you help me @Ehren?
Ehren Posted August 16, 2017 Author Posted August 16, 2017 Hello, I don't know the code off the top of my head, but please update your "Forum URL" so I can check your code. 1
DewDrop Posted August 16, 2017 Posted August 16, 2017 Done! The default language is Brazilian but it's possible to change it in the footer.
Ehren Posted August 17, 2017 Author Posted August 17, 2017 11 hours ago, DewDrop said: Done! The default language is Brazilian but it's possible to change it in the footer. This isn't the most flexible solution, but it'll work for your index page: /* Remove page title from index page */ li[data-blockid="app_cms_Database_vzlz60y0h"] .ipsPageHeader{ display: none; } 1
DewDrop Posted August 19, 2017 Posted August 19, 2017 On 17/08/2017 at 1:45 AM, Ehren said: This isn't the most flexible solution, but it'll work for your index page: /* Remove page title from index page */ li[data-blockid="app_cms_Database_vzlz60y0h"] .ipsPageHeader{ display: none; } Thanks! It worked.
dokdok Posted October 9, 2017 Posted October 9, 2017 On 12/8/2015 at 2:10 AM, Ehren said: To remove the "Forums" text on the index page, add the following to custom.css body[data-pagemodule="forums"][data-pagecontroller="index"] .ipsPageHeader{ display: none; } I did not find the code to delete this also in 4.2. Can I use this or is it better than no?
Ehren Posted October 10, 2017 Author Posted October 10, 2017 10 hours ago, dokdok said: I did not find the code to delete this also in 4.2. Can I use this or is it better than no? That code will work, but it'll also remove the Start New Topic button and your "fluid/grid view" buttons if you've enabled them. I probably wouldn't use this code on 4.2 on my own forum. 2
dokdok Posted October 10, 2017 Posted October 10, 2017 7 hours ago, Ehren said: Quel codice funziona, ma rimuoverà anche il pulsante Start New Topic e i pulsanti "fluid / grid view" se li hai abilitati. Probabilmente non avrei usato questo codice su 4.2 sul mio forum. Which code do you recommend to use for 4.2?
Ehren Posted October 10, 2017 Author Posted October 10, 2017 1 hour ago, dokdok said: Which code do you recommend to use for 4.2? What would you like to remove exactly? In 4.1, the header only contained text but in 4.2 there is extra content. If you still want to remove the entire header, use the code in this topic. Just be aware that users won't be able to change to fluid/grid view on the forum index. 2
dokdok Posted October 10, 2017 Posted October 10, 2017 Then this code is fine: in my forum I do not use "fluid / grid view" Thank you very much, Ehren 1
dj_jim Posted October 13, 2017 Posted October 13, 2017 how find this? body[data-pagemodule="forums"][data-pagecontroller="index"] .ipsPageHeader .ipsType_pageTitle{ display: none; }
Ehren Posted October 14, 2017 Author Posted October 14, 2017 7 hours ago, dj_jim said: how find this? You don't find it anywhere - just add that code to your custom.css file 1
Preston Davis Posted October 31, 2017 Posted October 31, 2017 This thread was very helpful in getting my site how I wanted it. I was able to get the Forums flush with the top how I wanted and got the header removed on Downloads. The one thing I can't find and would like to be able to do on the Downloads page is keep the submit a file button but put it at the bottom of the page so my downloads are flush with the top as well. I don't want to lose the button entirely just to move it. Is this possible? It's a small issue but it bothers me nonetheless.
Preston Davis Posted January 1, 2018 Posted January 1, 2018 Also, tried using this code to remove the header from my index page which worked but it also removes the content from the article when clicked on. It will only display the user feedback underneath. Is there a way to fix that? body[data-pageapp="cms"][data-pagelocation="front"] .ipsPageHeader{ display: none; } 1
Behzad4x Posted January 13, 2018 Posted January 13, 2018 On 1/1/2018 at 10:13 PM, Preston Davis said: Also, tried using this code to remove the header from my index page which worked but it also removes the content from the article when clicked on. It will only display the user feedback underneath. Is there a way to fix that? body[data-pageapp="cms"][data-pagelocation="front"] .ipsPageHeader{ display: none; } Hello Dear Ehren, This is my question too. This code remove all title from Article too. Please Help us resolve this problem. How change the code that remove only Title form page? Best Regards.
Ehren Posted January 13, 2018 Author Posted January 13, 2018 @Preston Davis @Behzad4x The HTML code on both the Article index page and Article view page is identical, so it's not possible to only target the index page using css unfortunately. 1
Preston Davis Posted January 22, 2018 Posted January 22, 2018 On 1/13/2018 at 6:02 PM, Ehren said: @Preston Davis @Behzad4x The HTML code on both the Article index page and Article view page is identical, so it's not possible to only target the index page using css unfortunately. @Ehren that's what I was afraid of. I wonder if that's a fix that could be suggested to them or if that would just be too much trouble. I know it's just being picky on my part but it would be really nice to be able to target one and not the other.
Ehren Posted January 23, 2018 Author Posted January 23, 2018 14 minutes ago, Preston Davis said: @Ehren that's what I was afraid of. I wonder if that's a fix that could be suggested to them or if that would just be too much trouble. I know it's just being picky on my part but it would be really nice to be able to target one and not the other. I unfortunately don't have a solution, sorry!
niK Posted April 20, 2018 Posted April 20, 2018 Hey @Ehren! When I add this code to the CUSTOM.CSS it removes the page title in all categories of my gallery albums. So, all navigation becomes compromised. Theres some way to remove only from Gallery Index? body[data-pageapp="gallery"][data-pagelocation="front"] .ipsPageHeader{ display: none; }
Ehren Posted April 20, 2018 Author Posted April 20, 2018 3 hours ago, niK said: Hey @Ehren! When I add this code to the CUSTOM.CSS it removes the page title in all categories of my gallery albums. So, all navigation becomes compromised. Theres some way to remove only from Gallery Index? body[data-pageapp="gallery"][data-pagelocation="front"] .ipsPageHeader{ display: none; } I don't believe there's a css-only solution for this. I think you'd need to remove the HTML from the index page.
