Ehren Posted April 7, 2015 Posted April 7, 2015 The default IPS theme is a responsive fixed width design. To make your design fluid (so it stretches to certain percentage of your browsers window), go to Admin Cpanel > Customization > Edit > Custom. Toggle the Enable fluid width? switch, and define your percentage in the box below. 2
kar3n2 Posted August 10, 2015 Posted August 10, 2015 hi Ehren What are the benefits of enabling fluid width? Does this mean that it will have the same look on all the different browsers? If so this is a good thing to enable for sure. (In my case for example, I always want a nice border to be showing with my background image, so I enabled fluid width of 85%.)
Ehren Posted August 10, 2015 Author Posted August 10, 2015 The fluid width simply means that your layout will stretch to whatever percentage you enter. It will look the same in all browsers. It's generally beneficial for larger monitors since your forum will occupy more of the screen.
