taman.sherzad@gmail.com Posted March 6, 2015 Posted March 6, 2015 hello If i purchase a skin for example villain, do i get support like change some of the colors and or making the logo bigger and changing position to somewhere else on top !? thanks
Ehren Posted March 7, 2015 Posted March 7, 2015 Hello, Villain was designed to be a dark template, so if you need to change the colours and convert it to a "light theme", it'll likely be priced as a custom theme. Minor modifications such as changing small areas of the theme will be offered for free. Redesigning the header is possible, however it may be classified as a paid modification depending on how much needs to be changed. Hopefully that helps - welcome to ipsfocus
taman.sherzad@gmail.com Posted March 8, 2015 Author Posted March 8, 2015 Thank you. so yea i just want to make the header look like this website http://www.adkgamers.com/ basically something like this one i edited villain on photoshop so exchanging positions of userbar and menu bar and putting a logo between of them just like the picture i think it doesnt need so much work also gotta say the skin is expensive and a little change and help will be nice thanks.
Ehren Posted March 8, 2015 Posted March 8, 2015 That is possible, however it would be easiest if I did it for you instead of trying to provide instructions. It will be a free modification.
taman.sherzad@gmail.com Posted March 8, 2015 Author Posted March 8, 2015 okay we have no problems Thanks and i will purchase as soon as i can but i also forgot to mention that a picture behind the logo , is it okay? best regards thanks you.
